show ip-security dhcp-snooping information circuit-id port-information
show ip-security dhcp-snooping information circuit-id port-information ports [port_list | all ]
Description
Displays the port information portion of the circuit ID for the indicated port(s).
Syntax Description
port_list Specifies one or more ports.
all Specifies all ports.
Default
N/A.
Usage Guidelines
This command displays the port information portion of the circuit ID for the indicated ports.
The following command:
# show ip-security dhcp-snooping information circuit-id port-information ports 1-7
Displays the following output:
Port            Circuit-ID Port information string
1               portinfostring1
2               portinfostring2
3               portinfostring3
4               portinfostring4
5               portinfostring5
6               1006
7               1007
Note: The full Circuit ID string has the form '<Vlan Info>-<Port Info>'
This command was first available in ExtremeXOS 12.3.
Platform Availability
